raptor 700 oil filter blues
Old Mar 27, 2006 | 11:07 PM
nicknamehere's Avatar
Default raptor 700 oil filter blues
I have an 06 raptor 700, got in it Nov. I've been riding the crap out of it and have had to change oil twice already, a third oil change is coming soon. with the internal oil filter, unscrewing and screwing those three bolts every 20 ride hours is worring me. How long before the threads strip and I have to get a new case? Do I really need to change the filter every time I change oil? both times i changed the oil so far (every 20 hours) it's needed it. help out please. thanks.
Old Mar 27, 2006 | 11:13 PM
Sorek's Avatar
I have changed a oil a few times in my 10+ years working on all different kinds of ATVS. I had a 99 400EX that i musta changed the oil a hundred times in. I have also changed the oil in these 700's. These bolts are meant to be in and out of the quad alot. One thing to keep in mind is to not be in a hurry when taking them out and putting them back in. I have not yet (knock on wood) had to tap a drain plug or oil filter lid bolt holes because I broke the bolts off or the threads got damaged. However, if you do happen to damage the threads this could probably be repaired without replacing a case half.
Sorek
Honda/Yamaha Tech
Old Mar 28, 2006 | 12:31 AM
Glamis700's Avatar
I got my 700 in Sept and have done 3 oil changes, one filter change.
You have nothing to worry about with the threads if the bolts are clean and you start them by hand. Start them with an impact gun and your asking for it!!!!!!!
Old Mar 28, 2006 | 09:28 PM
So would you say that I can get away with only changing my filter once every 80 or 100 hours and just make sure to change my oil every 20? thanks, any help appreciated.
Old Mar 28, 2006 | 09:52 PM
GmManDan's Avatar
In all my atvs I have had I change the oil every 50 hours then change the filter ever 100 hours and I have never had a problem. I wouldnt bother changing it every 20 hours I think that is over kill.
Old Mar 29, 2006 | 01:35 AM
thanks any more info would be helpfull. thanks again.
STLyamwar
Jul 25, 2020 04:44 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
carolinabomb
Jul 26, 2015 08:40 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
