Raptor Oil Problem
Old Apr 2, 2006 | 01:04 AM
Belleye's Avatar
Default Raptor Oil Problem
Hi, I have a 2005 Raptor 660r. It runs and rides fine but when i checked my oil the otehr day, the dip stick is reading below fill, to the point where u can just tell there is oil. I find this weird as i had just put in a quart and a half of oil. I checked the oil according to specs. I checked my radiator to see if maybee the oil was mixing in the radiator, but there is no oil in there. It is not leaking out and is not being let out through exhaust. I decided to drain the oil to see how much would come out to see if it was being burned, and i got almost 2 quarts of oil out. I then refilled it and re-ran the specified oil check. Same Problem. Any Suggestions would be helpful.
Thankyou
Dan
Old Apr 2, 2006 | 01:13 AM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
By any chance have you checked your air box, it may have some oil....
Old Apr 2, 2006 | 04:15 AM
yoshz's Avatar
How long had it been sitting when you checked it? Check the owners manual for the correct procedure. I think you have to warm it up, then let it sit for a couple of minutes. Also, you said you put in a quart and a half, did you just change your oil? It takes just a little over 2 quarts so if you only put in 1 1/2 that would be why.
Old Apr 2, 2006 | 12:52 PM
Belleye's Avatar
i did let it warm and then cool off, checked the oil and it was the same. yes, have checked the airbox and there no no iol in there, any othere suggestions?
Old Apr 2, 2006 | 12:55 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
is there any oil leaking near the front sprocket?
Old Apr 2, 2006 | 07:18 PM
Belleye's Avatar
no its clean. I did put a pipe on my atv and im thinking maybee this caused the problem? Any more ideas...
Old Apr 2, 2006 | 09:11 PM
Budwiser's Avatar
Just an idea coming from a newb, is there oil coming out of your exhaust?
Old Apr 2, 2006 | 10:07 PM
Belleye's Avatar
nope.. ITs burning clean. I was thinking maybee the exhaust pipe would cause more oil to be burned.. But i think a quart is alot to burn in 1 week
Old Apr 3, 2006 | 03:07 AM
bonebreakers's Avatar
with filter i believe it holds 2and a half quarts..have to break that 8 mill bolt loose to purge the air out on the side of the head....dont have a over size oil tank do you
Old Apr 3, 2006 | 12:17 PM
Belleye's Avatar
I figured out the problem. My oil seal is busted.... Gonna just send it to yamaha and have them fix it for me. I dont have time for yamahas garbage. Thx
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
