yfz 450 jetting question
Old Apr 7, 2006 | 11:07 PM
lightning21's Avatar
Default yfz 450 jetting question
how many rounds out should you run the fuel mixture screw, i put a dynojet jet kit in my 06 yfz and it said only one round out, and last night i put a gytr jet kit in my friends o6 yfz and it said run it 3-4 rounds out, what do you think?
Old Apr 8, 2006 | 02:21 AM
Scooter86's Avatar
Knows Old ATV Questions!
Ideally you want to be somewhere between 1.5 and 3 turns out. Even then 3 turns may be a bit far. 4 turns out is to close to falling out[img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 8, 2006 | 02:58 PM
2fun's Avatar
Exactly...
Old Apr 22, 2006 | 03:11 PM
bigdeala102's Avatar
who all is using dyno jet jet kits? someone please tell me ur settings and if it hauls *****...mine halls ***, but it dont haul *****...i need some help, such as ur needle position, jet number and where ur located, im at 1100 feet in oklahoma
Old Apr 30, 2006 | 06:25 AM
mushroom7380's Avatar
2 turns is the universal setting so you might want to try 2 and a quater to three turns, the best way to find out best setting is to run the machine, when it's idleing turn the air gas mixture screw out until the machine idles high the screw slowly back in until you get the machine to idle back normally, it's normally about an eighth turn in after you get the machine to idle high. This will set the mixture really really damn close
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
