Oil Change?
Old Apr 8, 2006 | 09:05 PM
ackademix's Avatar
Default Oil Change?
Hey guys, Finally getting my quad back after oil cooler snapped when i crashed. So i figure i lost alotta oil during that so i'd probably be better off changing my oil now. So how do i do it, I bought the Yamalube 4 stroke sae 20w-40 from Yamaha but i need to know how to perform the change if anyone can help.
Quads a Bruin 350 4x4
Old Apr 8, 2006 | 09:08 PM
Kharper450's Avatar
Default Oil Change?
No ideal what to tell you sinc ei have no ideal about the type of quad you have. But look in your manual and itll show you the bolts you need to take off. Also how much oil to put in it. It will be under the Maintence part check the page at the front.
Hope this helps!
Kevin
Old Apr 8, 2006 | 09:10 PM
ackademix's Avatar
Default Oil Change?
thanks ill check it out.
Old Apr 8, 2006 | 09:17 PM
Kharper450's Avatar
Default Oil Change?
Np all manuals have that in there. All the basic stuff is in there under the maintence. Changing plugs.. Cleaning filter..etc
Kevin
Old Apr 8, 2006 | 09:22 PM
ackademix's Avatar
Default Oil Change?
Any other maintenance i should do it hasnt been started since december 8th well i started it feb 12th i think but i turned it off quikly after like 3 seconds.
Old Apr 8, 2006 | 10:03 PM
Kharper450's Avatar
Default Oil Change?
Clean air filter and replace the oil one. Then check all fluids. Could also check your plug. In the back should be a maintence schedule. Goes by the hours that you have.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
