do you recommend flipping the wheels on my blaster
Old Apr 8, 2006 | 11:20 PM
warriorryder's Avatar
Default do you recommend flipping the wheels on my blaster
does thi give the machine more stability in corners? what does this do exactly....i flipped them around already to see if the valve stems would clear and they do so do you think i should do it? its either that or wheel spacers
Old Apr 8, 2006 | 11:24 PM
recon99's Avatar
It makes the quad wider so it's more stable and handles better. It's actually better than using wheel spacers, because wheel spacers can break, and they add some extra weight. I have the wheels flipped on my warrior, it's about 4 inches wider and it's been working great for me.
Old Apr 8, 2006 | 11:28 PM
thanks for the quick response...I'm gonna try it out when i get it back from the shop
Old Apr 8, 2006 | 11:40 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
it will make you wider,,,but you will experience a lot more bump-steer,,,and your front end will wear faster
Old Apr 9, 2006 | 12:17 AM
Wal2l2ioR's Avatar
i flipped em when i had my blaster and my ball joints went bad within 3 months. I did it after several people told me it worked fine on thier blasters...but i learned the hard (and expensive way) If you want a wider quad..do it right...save for the +4 a-arms.
Old Apr 9, 2006 | 12:25 AM
Bing's Avatar
Super Quad Patrol
ditto
Old Apr 9, 2006 | 01:47 AM
recon99's Avatar
Mine have been flipped for a year and a half and my ball joints are still in good shape. Maybe the blaster's ball joints are different than the warriors, but I think they are the same design.
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
Brandon400
Sep 5, 2015 08:44 PM
