Raptor 700r problems???????????
Old Apr 14, 2006 | 11:39 PM
fastestkidaround's Avatar
Default Raptor 700r problems???????????
Okay in August, I am getting a new raptor 700r and I wanted to know if their are any probs with it. Thanks and what are the best mods for it, and controller thing?
Old Apr 14, 2006 | 11:46 PM
bassmasterrap's Avatar
No problems for me yet. I have about 15 hours on mine. Check your lug nuts when you get it mine were loose and it ate my rim up. Also the water pump makes a noise when its cold. Hopefuly this will not be a problem
Old Apr 15, 2006 | 12:17 AM
Well thats not to bad... I heard about the rim thing, I read your post. Well the water pump might not be a problem, because it gets hot in Nevada, yet when I ride up here, it will be a problem but its only noise. thanks for the quick reply.
Old Apr 15, 2006 | 02:05 PM
Glamis700's Avatar
I havent had any problems with mine. The subframe is somewhat fragile, being cast alluminum.
Most common motor mods are intake, exhaust and programmer. The stock fuel management does not adjust for mods.
Aside from that, I put a twist throttle and 6 pack rack on right away along with paddles. I found out real quick that this bike is a wheelie machine, so i put a longer swingarm on.
Old Apr 18, 2006 | 02:31 PM
rouzer's Avatar
i have had mine for about a month now. the only problem i am haveing with mine is the chain was binding up when i was playing in the mud. i tightend up the chain. seemed to fix the problem for a while but it still does it once and a while. i still have my warrenty on it so i will be bringing it in soon to be fixed if it is still an issue. i just orderd rear tires for it. i wont be getting them till tomorrow so i will have to wait to find out. they are gators. 25-12-9 so it will give a little more ground clearnce. also just orderd a tuner for it.
Old May 30, 2006 | 10:42 PM
bendoverkawaskai's Avatar
did you have any problems with the subframe or is this just what youve heard?...
Old May 30, 2006 | 10:58 PM
quadbike's Avatar
No issues on mine, I have about 300 hours in the saddle [img]i/expressions/face-icon-small-smile.gif[/img]
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
