Replacing Headlights Raptor 660r
Old Apr 27, 2006 | 01:14 PM
mrdonthate's Avatar
Default Replacing Headlights Raptor 660r
How do you get the lens off to replace the headlights? I've been tryin to slide the tabs up and remove the clear lens but that's just not working. Is there some kind of seal of the lens? I need help! thanxx
Old Apr 27, 2006 | 01:44 PM
warwgn's Avatar
if your trying to replace the bulb it come out through the back not the front.
Old Apr 27, 2006 | 06:35 PM
mrdonthate's Avatar
THe lens and light are connected to the black holster from the back, how do i remove the lens from the holster to be able to get to the back to change the light?
Old Feb 12, 2007 | 09:02 PM
cerv's Avatar
ya thats the same thing im wonderin too! has anyone done this before?
Old Feb 12, 2007 | 09:10 PM
velocyraptor's Avatar
unscrew the bolts in the rear of the headlight, then atke off the front plastic, then take off the whole lens from the black plastic, then follow the wires until you see the black plastic boot, move it back and then push the bulb in then, turn it and pull it out, then take the bulb out from the headlight.
Old Feb 12, 2007 | 09:16 PM
cerv's Avatar
thanx alot, where can i get another bulb? auto parts store or dealer only.
Old Feb 12, 2007 | 09:45 PM
a store has bulbs but idk if some would fit, go to your dealer and buy some, or order some through rickystator.com they have bulbs that are of higher watts
Firefighter400
Oct 8, 2022 06:38 PM
blpersinger
Jul 15, 2015 09:56 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
