Raptor 700 Programmable Fuel Control???
Old May 10, 2006 | 04:18 PM
Tripleshot's Avatar
Default Raptor 700 Programmable Fuel Control???
Originally posted by: Glamis700
As far as compression braking, in the dunes, I like it to freewheel when I let off the gas.....like a 2 stroke would. The sand is enough braking under normal conditions.
Ditto that. Sand is a brake. And a cushion when you fall off.[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 10, 2006 | 06:25 PM
Lbags's Avatar
what about alcohol?
Old May 10, 2006 | 08:18 PM
lolachampcar's Avatar
Originally posted by: Lbags
what about alcohol?
You just apply about a 1.8 multiplier to the VE table to get you in the ball park. Although A/F changes from gas to alcohol, Lambda does not. A .8 to .9 lambda will work well in alcohol. Cosworth runs about .84 lambda in their ChampCar engines.
If a lot of people go this way, we will probably add a checkbox for fuel used so you do not have to change your VE table. Just check alcohol and go.
Old Oct 11, 2006 | 11:48 AM
The site is up at www.EFIDude.com.
You can see how we delt with Lambda, A/F Gas and A/F Alch by running the software demo. Goto to site map then click on software demo under the software tab.
STLyamwar
Jul 25, 2020 04:44 AM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
