how much to build a 686 raptor??
Old May 14, 2006 | 07:01 PM
03RaptorFan's Avatar
Default how much to build a 686 raptor??
Hi, I was wondering how much it would cost to build my stock raptor to a 686 and what kind of mods would i have to do? Thanks
Old May 14, 2006 | 07:44 PM
RAPTORJUNKIE's Avatar
Check out Craycraft Racing. They have one of if not the best 686 kit out there. Plus customer service is top notch. Just get their kit, or have something built for your budget.
Old May 14, 2006 | 07:49 PM
DriverDoyle's Avatar
Mr. Craycraft is the way to go...
Old May 14, 2006 | 08:08 PM
maddog56's Avatar
About 200-250 bucks. All you need is a bore job, gaskets, and a 102mm piston kit and you've got yourself a 686.
Old May 15, 2006 | 01:15 AM
bad350twin's Avatar
that is how the 686 is attained...... but to get the full benefit you will need porting,carbs,cam,etc.....to keep up with the other draggers! If that is what you do..... but if your on a budget and want a little more grunt just boring it will do that for you!
Old May 15, 2006 | 09:35 AM
warwgn's Avatar
the cost of a 686 is actually yet to be determined for sure!!! Once you start you never stop, with added power the waek links will start to show themselves so you will upgrade those 1 at a time. Then you will want more power and more upgrades and so on and so on!!
I assembled mine myself, and spent around $1000 to take it from bone stock to a Piped,jetted, camed,K&N, modded 686. Then started the up grades for all the weak stuff I started finding.
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
