AMP link?
Old Nov 21, 2000 | 01:09 PM
Zorro's Avatar
I was thinking about the AMP link. Does it really work the way it's advertised? If it does, I guess the mass transfer would give way more traction. But is it true that the rear susp is blocked under power (or is unable to react properly)? And if yes, is it true that that the AMPlink changes something?
Old Nov 22, 2000 | 05:45 PM
BigRider504's Avatar
i say forget the amp-link. i had one on my warrior and the bearing blew out of the top of theamp link and threw a bunch of slack in my chain, then my chain shot up and broke 2 teeth on my front sprocket, broke my chanin guard and blew a big *** hole in my crankcase,at least i think it is called the crankcase, well it was part of the motor anyway and it wasnt cheap to fix. I took the amp link off then because they wouldnt sell me another bearing and i wasn5t about to buy a new one. the truth is i cant really notice much of a difference without it, a little acceleration is lost right when i land a jump but thats about it.
Old Nov 22, 2000 | 11:31 PM
scottd's Avatar
AMP link? Can you say J-U-N-K?????? If you're that gullible, let me think up of some useless gadget to sell you! A word to the wise is sufficient! Read the post above mine again, and pay heed!
Old Nov 23, 2000 | 01:05 AM
chriscoll1's Avatar
Actually the AMP link does work.Most people were too stupid to set it up right.I used one for about a year.It did help my Banshee hook up a little better(but not that much).Yes the bearings and sprockets wear too fast.But if you check them regularly(same as any other part of your quad) you wont have a problem like the last guy,thats common sense checking this stuff.Also you dont adjust the chain the same way with one on.
I still dont recomend it.They are not worth the effort for what little it does.
Old Nov 23, 2000 | 02:54 AM
400exman's Avatar
don't waist the $ PERIOD!
Old Nov 23, 2000 | 02:55 AM
400exman's Avatar
don't waste the $ PERIOD! does nothing!
salixair
Nov 3, 2015 08:25 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
bigred20653
Oct 2, 2015 10:05 AM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
