Wont Start
Old May 15, 2006 | 06:10 PM
87250xman's Avatar
Default Wont Start
I have a 2003 Warrior. When I try to start it it cranks but dosnt catch. I know its not the battery. What could it be???
Old May 15, 2006 | 09:09 PM
recon99's Avatar
Default Wont Start
Check for spark and fuel. Unplug the spark plug wire, plug it into a spare spark plug, and touch the threaded part of the spark plug to ground. Crank the engine and watch for a spark on the tip. If you crank the engine and don't get a spark that gives you somewhere to start. If it does spark, then you probably have a fuel issue.
Old May 15, 2006 | 11:09 PM
87250xman's Avatar
Default Wont Start
It dosnt have a spark. Tried new plug then checked for power at the coil, no power.All line and connections are tight and not rusted. Is there a way to test the CDI?
Old May 15, 2006 | 11:20 PM
recon99's Avatar
Default Wont Start
Usually when a CDI goes bad it burns up, and you can tell by just smelling the back of it.
I think it's more likely that it's a problem with the stator or pickup coil. A service manual can tell you how to test them.
Old May 15, 2006 | 11:32 PM
87250xman's Avatar
Default Wont Start
I dont have a service manuel so any info you can post to help me with testing it would be a big help. Where is the pickup coil? This quad have less then 50hr's on it and has never been in deep water.
Old May 15, 2006 | 11:53 PM
recon99's Avatar
Default Wont Start
The pickup coil and stator are in the left side of the motor. There will be a few wires coming out of the engine, that's where it is. I can't really tell you how to test it, because every manufacturer/model is different. A repair manual is a good investment, i recommend that you get one.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
