YFZ 450 running hott
Old Jun 16, 2006 | 02:49 PM
Yfz45016's Avatar
Default YFZ 450 running hott
I have a 04 YFZ450 thats stock and when I ride it in the summer heat the exhaust is almost unbearable. I took the lights off the front to maybe push more are into the radiator so it runs cooler but nothing. Is this a problem or do most of them do this. Also at night the exhaust glows red hot.
Thanks alot,
Nate
Old Jun 16, 2006 | 04:18 PM
JLsparky7's Avatar
Try getting some new coolant.
Old Jun 16, 2006 | 05:42 PM
RAWYFZ1973's Avatar
Is it just putting out alot of heat or is the engine actually running hot. Because it is normal for alot more heat being put off by the header pipe compared to other bikes. And the header glowing at night is normal.
Old Jun 16, 2006 | 05:56 PM
Yfz45016's Avatar
Yeah it just puts off alot of heat and is almost not fun to ride when your just cruising because the heat almost burns my leg. Thanks for the info I didnt want to be hurting my engine because its running to hott or something.
Thanks,
Nate
Old Jun 16, 2006 | 06:52 PM
Scooter86's Avatar
Knows Old ATV Questions!
Are you wearing shorts? If it is a real problem, there is a number of things you can do to make it run cooler. Install a larger radiator, run water wetter or engine ice, put on an inline cooler, etc. etc.
Old Jun 16, 2006 | 08:48 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
exhaust tape
Old Jun 17, 2006 | 05:24 PM
YamiYFZ's Avatar
mine does the same thing and its normal. when i got my CT pipe it was even worse and theres not a heat sheild on this. i have big burn scars on the inside of my leg from accedently rubin on it. all my jeans have holes burnt through them. i would wrape in in heat wrap, thats what im gonna do soon. its suposed to help Hp too.
Old Jun 17, 2006 | 05:39 PM
Scooter86's Avatar
Kind of off topic, but YamiYFZ, does your header come way out toward your leg or something? I have an HMF full system and have never had a problem with burnt pants. Come to think of it, engine heat doesn't really bother me that much either.
Old Jun 17, 2006 | 10:11 PM
Raptor149's Avatar
To clarify,
I see this as a common response from people. Your header glowing red is not normal!!!
As for your bike running hot, there are a number of things you can try. Check your thermostat, it might not be opening. Also, try replacing your stock coolant with something that runs cooler like Engine Ice. These are cheap solutions.
Bigger raditors are expensive, yes, but they do the job.
Old Jun 17, 2006 | 10:51 PM
Scooter86's Avatar
Actually, a lot of the newer exhaust systems are running a thinner stainless steel than in years past, especially aftermarket. It is possible to be jetted correctly and have your header glow a bit.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
