Raptor hicomp. piston
Old Jun 19, 2006 | 07:06 PM
fasterthanyou22's Avatar
Default Raptor hicomp. piston
What kind of gas would i have to run in an 11:1 raptor? Could i still run pump gas? Like 93? Or would i have to run higher octane, because i want a high comp piston but if i cant run 93 in it then i wouldnt ride it too much..
Old Jun 19, 2006 | 09:55 PM
silent101's Avatar
i beleave 11.1 is pump preamum. 12.1 or more is race fuel or oxyginated fuel. the problem with puting in a piston would be it will put alot of strain on other components in the engine for example the starter will crank hard and you will go through starters like a bad habbit. also plan on you're battiries being drained all the time. Theres a binch more things that just were'nt made for the high compresion and I dont know about you but I like to ride more than wrench not to mention that its no small job putting in a piston and can cost alot more than that 100 dollor wissko piston kit you're eyeing up on ebay. anayway if you're going to go into you're quag make sure you get an upper end gasket kit and a larger cam but not to big because you will suffer on the bottom end. Also eather get it bored if its scared real bad or get it brazed if you're going to drop a stock size in. You're talking atleast 250.00$ and a lot of work all for about 5 HP.
You're call
Old Jun 20, 2006 | 05:36 AM
maddog56's Avatar
11:1 will let you use premium pump gas which ranges from 91-94 RM/2 octane.
Putting in a piston isn't a huge deal, especially if you have a hone and the cylinder wall is in good shape. The only way a 125 dollar piston and 15 dollar gasket turns into a 250 dollar job is if you need the cylinder bored and honed and you have someone else install all of it.
Old Jun 20, 2006 | 11:25 AM
RDZ350's Avatar
Make sure to put the bolts back in where they came from.I think it's the 4 bolts that hold the jug to the case.They are not all the same length.2 are longer than the other 2.We put a short one where a long one went and stripped out a bolt hole.Thought you should know.
Old Jun 20, 2006 | 12:20 PM
silent101's Avatar
Ya If you know what you'r doint it dosent take forever but iv seen alot of people mees up things in the engine and when you put a high comp piston u defentaly need to put a cam in it. Its the only way to go. As you can see I am agenst engine mods. Maby thats why my things are so slow? Plus if you go to a shop i will bet you it will be 500 atleast, Shoot they want 250 for puting rear axle bearings in.
Old Jun 20, 2006 | 02:46 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
i've had my 11.5:1 in for a few months now and no starter problems. oh and i run 93 octane with no problems.
Old Jun 20, 2006 | 03:27 PM
Yea, but the raptor is opt for starter problems. Oh well, just another thing to do to it, gotta get cam and of course piston.
bmxatv10
Oct 14, 2022 06:23 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
black_thunder
Sep 22, 2015 07:59 PM
