help me out
Old Jun 22, 2006 | 06:23 PM
farmerjohn's Avatar
Default help me out
i started messing around with my clutch because i ordered a new lever for it. i unscrewd that metal piece that the wire runs out of, not all the way out, and now the atv wouldn't go into gear. no problem, so i screwed it back in where i thought it was but the atv still barely moves. what do i do?
i hadn't used the thing in a while if that might help . it's an 06 raptor 350
Old Jun 22, 2006 | 10:02 PM
madmad's Avatar
Default help me out
Unscrew the locknut at the perch all the way back, then screw the adjustment screw in until you have about 10 mm of freeplay at the end of the lever. When i say freeplay, that means the distance that the lever on the handlebar moves, at the end closest to your little finger, before the lever on the clutch cover satrts to move.
Old Jun 22, 2006 | 11:12 PM
farmerjohn's Avatar
Default help me out
can you explain it in dummy terms for me please
