loud yamaha warrior
Old Jul 9, 2006 | 10:59 PM
ZapooMafoo's Avatar
Default loud yamaha warrior
Is there a silencer on a stock yamaha warrior exhuast? Or how do you make it louder. Like a real 4-stroke.
Thanks
Old Jul 9, 2006 | 11:03 PM
Baseballroxmasox's Avatar
All stock quads have silencers. But you can buy an aftermarket slip-on to make it louder. Or to make it real loud, buy a whole system! A little more money though, later man,
zach
Old Jul 9, 2006 | 11:15 PM
ZapooMafoo's Avatar
where is the silencer located, and can it be removed.
Old Jul 9, 2006 | 11:18 PM
The silencer is the last thing on the exhaust pipe. It is the bigger thing on the end. Yes, it can be removed, on some quads it is easy, some aren't so easy. Later,
Zach
Old Jul 10, 2006 | 12:40 AM
DriverDoyle's Avatar
Well on a stock warrior you can pull the end cap off of it and be ok.. You not going to gain anything by doing so..all it is going to do is make it loud...On a stock motor you need some back pressure for it to run right...But its your quad you do what you want with it..And i know what your going to say if you look in my pics..Yea im running drag pipes but im running very high compression.. so im doing it to gain HP...But good luck with your warrior..
Old Jul 10, 2006 | 10:03 PM
ZapooMafoo's Avatar
when you take the end cape off is there any backpressure left.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 10, 2006 | 11:40 PM
recon99's Avatar
Don't take the baffle/spark arrestor out, it sounds like a broken lawnmower. Louder is NOT better with the stock exhaust. Just spend $220 for a decent slip-on exhaust instead. If you want good sound and bang for your buck you can't go wrong with an HMF. You'll drop about 5 pounds of dead weight, it'll look a whole lot better than the cheesy stock one, you'll actually get a power gain, and it will sound sweet.
Old Jul 11, 2006 | 12:10 AM
Recon99 hit the nail on the head...I 2nd what recon99 said...
Old Jul 11, 2006 | 04:48 PM
ZapooMafoo's Avatar
even though it sounds like a broken lawn mower. is it bad for the motor?
Old Jul 11, 2006 | 09:04 PM
No it not bad for it.. Your just going to lose power...if you take it out.. you need a k&N or uni air filter.. and your need to rejet it to get more power.. If you just pull it out.. its going to start running a little lean and that is bad for your motor..
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
mrmickman123
Aug 30, 2015 10:37 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
Ashley S
Jul 31, 2015 09:46 AM
