2-stroke motor question...Help?
Old Jul 18, 2006 | 04:10 AM
DesertBum's Avatar
Default 2-stroke motor question...Help?
Got son's dirt bike back and put fluids in and coolant poured into the oil area and came out the oil plug. What happen? We got it back in piece's in a bucket and decided not to let the shop do any work and put it back together ourselves. It's a 125cc dirt bike.
Any help would be great!
Update: Son said coolant came out first, then the oil did. They weren't mixed.
Old Jul 18, 2006 | 04:34 AM
ThrashAndCrash's Avatar
What year and make of dirtbike
Old Jul 18, 2006 | 04:44 AM
Waterpump seal
head gasket/ and crank seals
Why did the shop have it in pieces? What was wrong in the first place?
Old Jul 18, 2006 | 04:52 AM
DesertBum's Avatar
Had a hard time starting it. Would have to pull start it with my quad. They said it need work. I disagreed. I went and got it back. Took top end off and the piston looks fine.
1988 YZ125
Old Jul 18, 2006 | 05:20 AM
JLsparky7's Avatar
Most dealers have a chart on there computer of all the gaskets and such that seperate all the fluids. Ask them if you can take a look at it and see if you can find the prob.
Old Jul 18, 2006 | 05:22 AM
Just because the piston looks fine means nothing................Did you check the piston to wall clearence? How are the rings? what did the cylinder wall look like?
If all you did was put the upper end together, did you get new head o-rings? one may have got out of the groove when you torqued the head....
Just brain storming for ya...........
Old Jul 18, 2006 | 02:34 PM
DesertBum's Avatar
Thanks. I'll look.
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
