How Much hp. Banshee
Im will be getting the Toomey t-5 Kit. Pro deseign cool head 20cc domes. And a proflow package. Possibly after that ill purchase some 28mm or 34mm CArbs.
Plus will it beat my 06 yfz with a cam mod , curtis sparks full exhaust.?
i picked up my banshee from the dealer today. next week will be toomey pipes airflow-port and polish high compression. i will use the same carbs with bigger jets and burn race fuel.and drop to a 13 sprocket.remember modding the exhaust and intake makes the motor run leaner, so if you add larger carbs you will lean it out even more. [however unless you want to burn alky. alky cools the charge so therefore you can have larger carbs.]
well, i got back the banshee from the dealer this afternoon, took it out for the first after the upgrades, took it easy till break in, but it does have more grunt low end, and for sure upper end. i think i will be happy for awhile. also got my works shocks today. i will put them on tomorrow and post a new pic. the shocks look great, springs are red,white ,blue. body is black, top and bottom is gold anodized.
Jul 7, 2015 11:00 PM
