Yamaha Warrior 350
Old Sep 3, 2006 | 10:14 PM
Smooth's Avatar
Default Yamaha Warrior 350
I have a 2000 yamaha warrior 350. I just brought, that had a bad bottom end. So I replace the bottom end, and now it want hold a charge, and the motor is not raising up it just sputtler and backfire. Seem like it outta gas, but its not outta gas, I clean the carb. The spark plug look good, what can the problem be.
Old Sep 4, 2006 | 12:48 AM
recon99's Avatar
A few ideas that come to mind are the parking brake rev limiter could be stuck, there could be a problem with the stator or coil, you could have a crack in the intake manifold, or your valve timing could be wrong.
Old Sep 5, 2006 | 04:25 AM
Decimus's Avatar
Sounds like timing to me.
Old Sep 5, 2006 | 05:52 AM
Smooth's Avatar
I got it running right it was the parking brake swith.....
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
