bear Tracker Idle
Old Oct 6, 2006 | 06:15 PM
hunteraz's Avatar
Default bear Tracker Idle
I have a bear tracker 250. I have problems with it ideling too fast or too slow. In first gear it does fine, but when I put it into neutral it sometimes idles to fast, so I pull the choke and it goes back down. Wear is the idle adjustment on this? I have looked all over the carb for it.
Thanks
Old Oct 11, 2006 | 12:28 AM
doggster's Avatar
Looking at the 4 wheeler from the left hand side (if you were sitting on it) you should be able to find the idle adjustment **** on the bottom of the carb. Mine has a goldish metal look to it and you can turn it with your fingers. I use to have the same problem when it was new but I've got it dialed in nicely now. Hope this was helpful.
Ean
Dec 19, 2022 08:48 AM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
house1
Aug 9, 2015 10:49 PM
clsharky
Jul 13, 2015 02:07 PM
