Kodiak 450 speed limiter problem
Old Oct 8, 2006 | 03:52 PM
squeege's Avatar
Default Kodiak 450 speed limiter problem
should be limited to 20mph i think......I would also return it.....could be a defective or stuck override switch....?
Old Oct 8, 2006 | 03:55 PM
power123456789's Avatar
is there a way that i can find out what speed it should start to limit me at. And i have a warrenty on it so if there is somthing wrong with it, it should be covered. i am just fustrated because i hate it when there is something wrong with brand new stuff like this.
Old Oct 8, 2006 | 03:58 PM
wille's Avatar
read your owners manual it might be in there
Old Oct 8, 2006 | 04:00 PM
i checked it just says "will go the speed of the speed limiter" and thats it. do you have this type of atv. and do you think it will be covered for free
Old Oct 8, 2006 | 04:07 PM
  #15
Does anybody know what speed the speed limiter should kick in at and keep it slow while in diff. lock
Old Oct 8, 2006 | 04:09 PM
  #16
wille's Avatar
as long as your machine is still under warranty it shouldnt cost you anything, im sure someone will eventually have a definite anwser for you. i used to have a kodiak 450 but i traded it in.
Old Oct 8, 2006 | 04:11 PM
  #17
thank you
Old Oct 8, 2006 | 04:12 PM
  #18
i geuss if anybody knows the speed it should be limited too in diff lock. please please reply
Old Oct 8, 2006 | 04:18 PM
  #19
i just found out that i was only going 19 across the yard real quick could this be to slow for the speed limiter to engage whil in diff lock
Old Oct 8, 2006 | 05:11 PM
  #20
hondabuster's Avatar
How about reverse? Can you hit the rev limiter when in reverse?
I think the rev limiter for diff lock is only in low range..try doing it in low, and see if you hit the limiter, and then press the over ride button and see if it goes away.
