Banshee Waterpump
Old Dec 1, 2006 | 07:18 PM
URCRAZY's Avatar
Default Banshee Waterpump
My son bought a aftermarket water pump for his Banshee. Is there a certain way to pull this little impellar out, or just pry it out? I never have done this, and dont have a repair manual. I dont want to break it.. So any suggestions?
Old Dec 1, 2006 | 09:53 PM
GRNDHUSTLE's Avatar
you might want to check on this link bansheehq.com its all about banshee and banshee questions like these. hopefully that helps.
Old Dec 3, 2006 | 11:23 PM
reddogleader's Avatar
hello i put a aftermarket impeller in my bike. you have to take brake lever off and remove entire cover. along with the small cover that hides water pump. make sure you have the side cover gasket before you start. when you get large side cover off there will be a small pin and a clip that hold impeller shaft in place/ once cover is off it is a breeze..
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
