01 warrior turns overs but doesn't start
Old Dec 31, 2006 | 07:20 PM
jamitch400's Avatar
Default 01 warrior turns overs but doesn't start
my warrior turns over but doesn't get any spark, the rotor is turning, and when the atv is push started it will start. not to sure what that could be. ANYONE GOT ANY IDEAS.
THANX
Old Dec 31, 2006 | 07:47 PM
warriorryder's Avatar
get a new coil or resistor cap
Old Jan 2, 2007 | 01:56 PM
jamitch400's Avatar
but i dont understand how it could be the coil, because when i push start it i get spark and it runs. if the coil was bad it wouldn't get any spark?
Old Jan 2, 2007 | 05:03 PM
that is true but I have seen it happen many time where there isn't enough spark from turningthe motor over via kickstart or starter but there is enough when it is push started...so check your electrical stuff
Old Jan 2, 2007 | 06:42 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
so therefore.. i'd say check your stator..
Old Jan 3, 2007 | 12:41 AM
jamitch400's Avatar
not really sure how the stator works, but doesn't the rotor spin around it creating the power, but the motor turns over when pushed. but i'll check it out
Old Jan 3, 2007 | 03:41 PM
jamitch400's Avatar
ive also noticed once i push start the atv and let it run for a while, then shut it off, it will restart by hitting the start button, but once it sits over night, it will no longer start without pushing it again.
Old Jan 3, 2007 | 03:46 PM
ATV_MAN's Avatar
Had the same problem you descrbied with my Wolverine, replaced my Coil, but that wasn't the problem, replaced my Stator and it runs like new now.
Old Jan 3, 2007 | 05:14 PM
bombrider04's Avatar
yea I would have to say that it's either the battery or the stator.
Old Jan 4, 2007 | 01:02 AM
jamitch400's Avatar
yeah i seem to be leaning more towards the stator, but not sure how it could be the battery if it is turning over.
