alcohol--methanol
Old Jan 9, 2007 | 10:52 PM
raptor660SRX's Avatar
Default alcohol--methanol
Looking for kit or jets for a 02 raptor 660 carbs to convert it to run on alcohol instead of gas......cant seem to find anything......any help would be great.....
Thanks........
Old Jan 10, 2007 | 01:55 AM
bad350twin's Avatar
are you running stock carbs? if so you will probably have to find the biggest main you can get and drill it ! Better yet call Robertson Cycle (402)339-1814 ask for Mark, he can help!
Old Jan 10, 2007 | 10:00 AM
UBETRUN's Avatar
The stock carbs barely flow enough fuel to feed a built motor on gas, I wouldn't even try to run them on alky. Save your pennies for a good set of carbs, FCRs if you are playing and Lectrons if you are only racing.
Kenz Cycle Tech or Dennis Packard for 41mm Lectrons, Craycraft Racing or Tim Barker or Coal Shed Racing or Sparks for 39mm FCRs.
Old Jan 11, 2007 | 03:37 PM
thanks for the help i will check into it
Old Jan 11, 2007 | 04:33 PM
DriverDoyle's Avatar
Or you can call Bob CrayCraft 1-870-542-5133 he can hook you up too.
