warrior running bad?
Old Jan 22, 2007 | 03:06 PM
tiner's Avatar
Default warrior running bad?
my brothers 99 warrior about a month ago started to run bad. at first it just took for ever to warm up. now it is hard to get it to warm up and when it is idleing it backfires and pops evry few seconds but runs fine while riding. does any one have an idea wat it could be.
Old Jan 22, 2007 | 03:17 PM
jaygood17's Avatar
Does it run any different with the choke on or off? It sounds to me like you have a clogged jet.
Old Jan 22, 2007 | 03:22 PM
98warriortaz's Avatar
How about th parking brake? Unhook that to see if it is causing problems. With it on it will sputer and back fire if you give it gas.
Old Jan 22, 2007 | 03:25 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
go to the back of the quad by the brake and push the parking brake forward( bottom toward the carier) this should fix it.. if it does.. go t othe dealership and get a block off plate and remove he parking brake
Old Jan 22, 2007 | 06:40 PM
rruser's Avatar
He said it runs fine when riding. The E-brake can always be a problem but it wouldn't be able to go above idle. I would do what jaygood17 said and check how it does on the choke. Did this problem happen to change when cold weather came back? What happens when you downshift? does it also pop and backfire?
Old Jan 22, 2007 | 07:05 PM
JLsparky7's Avatar
98% sure this is your problem. Richen your idle jet, give it a 1/4-1/2 turn counterclockwise.
Old Jan 23, 2007 | 12:46 PM
tiner's Avatar
ya its not the e- brake beccause it does run fine when you are driving it. it mostly just makes a popping sound when idling and i believe when decelerating. is the idle jet the one that you can just adjust by hand? the idle also spikes when sitting with the choke on and occasionaly with it off. thanks for the help please keep it coming
Old Jan 23, 2007 | 07:57 PM
JLsparky7's Avatar
The idle jet is usually a 1/4inch or so straight head screwdriver screw on the side of the carb. What your thinking of is the idle throttle adjustment, thats a little different. Its probably the idle jet or an air leak somewhere. Try the jet first, it should be right on the side of the carb and fairly easy to get to. Look at both sides.
Old Jan 23, 2007 | 08:02 PM
lucasislight's Avatar
the screw is on the bottom of the carb on the motor side...you can get to it with a stubby screwdriver, or just a flathead bit and yor fingers.
Old Jan 23, 2007 | 11:15 PM
tiner's Avatar
thanks, are there any more ideas because i cant work on it till the weekend so the more ideas i get the better.
