yamaha 350 warrior problem
Old Jan 24, 2007 | 08:20 PM
Ryan112172's Avatar
Default yamaha 350 warrior problem
my warrior is an 02 and i just put on a dg xccelerator stage 2 exhaust on a few weeks ago. it was running fine and now i have no power at all. it does not have anything to do with the jets. i was in 6th gear and was only about 35 or 40 mph and is about half the speed it used to be . not sure if the problem is in the transmission or engine. if anyone can help please tell me. thank you
Old Jan 24, 2007 | 08:27 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
check your parking brake..
also.. is it sputtering past half throttle at times and other times isn't?
Old Jan 24, 2007 | 08:29 PM
Ryan112172's Avatar
no it runs fine and no sputtering. 4th 5th and 6th gear are all about the same speed.
Speedy2222's Avatar
hhmm i'd say it's your parking brake..
Old Jan 24, 2007 | 08:34 PM
Ryan112172's Avatar
the parking brake is off i still think it has something to do with the transmission.
Old Jan 24, 2007 | 08:36 PM
Speedy2222's Avatar
off.. as in.. OFF or as in.. off the quad completely?
Old Jan 24, 2007 | 08:38 PM
Ryan112172's Avatar
its on the quad.
Old Jan 24, 2007 | 08:39 PM
Speedy2222's Avatar
take it off and put a blockoff plate on.. i had this problem wit hmy dad's quad and i just had enough and took it off.. if u want u can just take the cable off and undo the wires in the front and leave the part on the rear caliper until u buy a blockoff plate
Old Jan 24, 2007 | 08:40 PM
Ryan112172's Avatar
ok ill try that thank you
Old Jan 24, 2007 | 08:46 PM
Speedy2222's Avatar
let me know how it goes
