Raptor jet kit installation advice
Old Jan 25, 2007 | 05:09 PM
jremmart's Avatar
Default Raptor jet kit installation advice
I am getting ready to install a dynojet kit in my 04 raptor. I am also installing a pro series air filter kit. That is pretty easy. I am just looking for some do's and do not's when installing the jet kit. I have read some about having to sync the carbs. If all I do is replace the main jets and the needles will I have to worry about syncing the carbs?
Old Jan 25, 2007 | 06:05 PM
SickSixtyRider's Avatar
If you take the carbs out as one you won't have to sync them. just take the bowls off and change the jets.
Old Jan 26, 2007 | 09:12 AM
jremmart's Avatar
Is this the same for doing the needles too?
Old Jan 26, 2007 | 09:25 AM
jwadd66's Avatar
Hi,I used a Dyno jet kit on my KFX and couldnt get it to run with the kit.I would use the jets that came with your carbs and go up a size or two bigger.I have a 2003 Raptor with a full Yoshi exaust and a Pro design air box and lid it runs the 160 165 jetting.
Old Jan 26, 2007 | 10:47 AM
if your changing the needles, u can keep the carbs right in the machine. just take the caps off the top.
HYS
Aug 18, 2015 12:28 PM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
