Banshee carb???
Old Feb 18, 2007 | 08:16 PM
bllabong89's Avatar
Default Banshee carb???
For some reason, when ever i have the fuel turned on, my right carb leaks gas out of the over flow tube from the bowl. I took apart the carb and cleaned it and put it back together and it still does it. If anyone knows what might be wrong, please help. Thanks
Old Feb 18, 2007 | 08:42 PM
JLsparky7's Avatar
Your carb float is set wrong. Adjust it till it stops leaking.
Old Feb 18, 2007 | 10:32 PM
bigdad390's Avatar
Float level set to high.
Heavy float, as if there is a pin hole or crack and the float filled with gasoline causing it to sink.
Worn or damaged needle and seat.
Old Feb 18, 2007 | 11:12 PM
bllabong89's Avatar
would this cause any other problems as in bringing down the peak performance or anything?
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
