dim headlight on yfm200
Old Feb 20, 2007 | 06:50 PM
johnboy01's Avatar
Default dim headlight on yfm200
I have a 1989 yfm200dx that has a headlight problem. The headlight is very dim, to the point it doesnt illuminate anything. Anyone have any idea what to troubleshoot?
Thanks,
johnboy01
Old Feb 21, 2007 | 12:44 AM
rruser's Avatar
The best idea would be to check how much power is being sent to the light with a voltmeter. You might also have a bad ground in the wiring. Check your wires under the front grill area.
Old Feb 21, 2007 | 04:02 PM
johnboy01's Avatar
Figured it out. Someone had tied the hot and ground for the tailight together (i bought it used) I measured the DC voltage and there was none, when I fixed the wiring all I could get was AC voltage. Apparently this headlight works on AC not DC. Thanks for the help.
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 16, 2015 01:33 PM
