SOMEONE PLEASE HELP
Old Feb 25, 2007 | 08:51 PM
Raptorracer2051's Avatar
Default SOMEONE PLEASE HELP
Alright i just got done taking the parking brake off my 660..when i went to unplug it at the white connector behind the radiator instead of the connector coming apart i accidentally ripped the wores out of the white plug..i didnt think it was a bid geal so i went ahead and took the e-brake cable out and put on the blockoff plate...well i went riding this past weekend and it was doing fine...after ridin about an hour i cut it off( used the red kill switch) and turned the ignition off..when i went to turn the key back on nothing happened the neutral light or none of that works, the starter button, nothing theres just no electrical power to the quad..does anyone know whats wrong? maybe those loose wires shorted something out?? cdi box shorted out?
Old Feb 25, 2007 | 09:31 PM
v2rider's Avatar
Check your battery connections first, then check fuses..................
Old Feb 25, 2007 | 09:41 PM
battery connections are good...where are the fuses?
Old Feb 25, 2007 | 09:43 PM
v2rider's Avatar
Im not sure on the Raptor. Mine are behind my battery box
Old Feb 25, 2007 | 10:58 PM
Speeddrive1's Avatar
why did you remove the parking brake? Was it broken or causing problems?
Old Feb 25, 2007 | 11:07 PM
yea the e brake rev limiter kept activating
Old Feb 26, 2007 | 01:30 AM
thanks guys i found the problem..the wire going to the positive battery terminal broke somehow..
