87 moto 4 80cc badger, fuel problem help?
Old Feb 26, 2007 | 04:21 PM
ctateusa1's Avatar
Default 87 moto 4 80cc badger, fuel problem help?
I just rebuilt the engine on the badger, the carb is getting gas, I can pull the screw out of the bottom of carb and it is getting fuel but I dont think that it is actually going from the carb to the engine, what could cause this.
Any help would be appreciated.
Old Aug 10, 2007 | 10:14 PM
pwhs's Avatar
timing easy totime
Old Aug 11, 2007 | 08:29 AM
atvingnc's Avatar
either the timing between the crankshaft and the cam is wrong, the valve rocker arms aren't adjusted right or the engine compression is low. did you try spraying a little starter fluid in the intake of the carb while cranking the engine.
skinnyr6
Aug 25, 2023 02:18 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
