2006 Raptor 350 Reverse troubles
Old Mar 10, 2007 | 07:50 PM
trxrevoraceros18's Avatar
Default 2006 Raptor 350 Reverse troubles
Hey guys, ive been having trouble with my reverse. It engages fine, from forward to reverse, but from reverse to forward, it goes in when it wants to. Sometimes i put it in what would be first, and release the clutch halfway, and sometimes it goes in then, but sometimes it takes a long time to go in. What could cause this? Its on a 2006 Raptor 350.
Old Mar 10, 2007 | 09:43 PM
MrBobby's Avatar
yeh mine does the same thing but if im having trouble wiht it i just turn it off put it back in forward then turn it back on.... :/
Old Mar 10, 2007 | 10:50 PM
yotatrailrunner's Avatar
My wifes 2007 does the same thing. From what i found out it uses the same reverse system that the older warriors used. When the bike is cold it is very easy to get into reverse but when the engine gets hot its alot harder. Its been a problem with the warrior/raptor 350 since 1989 when they first came out. Only thing you can do is try to rock the machine or switch it from reverse to forward while the bike is still moving backwards.
Old Mar 11, 2007 | 09:26 AM
I get it 7 times out of 10 when its rolling in reverse, the other times, i have to either shut it off, or get it as far as i can, put it in first gear, all the way down, and let the clutch go halfway and it pops in and i can go then.
Old Mar 11, 2007 | 11:36 AM
ss97's Avatar
Lets Ride!
Yup, My Wife's does that sometimes, as did our '01 Warrior ....
And as was said, rocking the machine back and forth seems to work most of the time for us....
Old Mar 11, 2007 | 06:11 PM
MrBobby's Avatar
agreed rolling back and forth works...most of the time
Old Mar 11, 2007 | 09:42 PM
warpigs's Avatar
I just jiggle the lever while thrusting back and forth (kinda sexual isn't it) and it finds it's way back in.
Old Mar 11, 2007 | 09:48 PM
Hoyt34's Avatar
mine did the same thing all i did was kind of rock it back and forth and work the clutch.
Old Mar 12, 2007 | 11:16 AM
54warrior's Avatar
Yeah, everyone that has a Warrior has said they have this problem. Mine is not too bad, its a 96, just wiggle and use the clutch like everyone else. I've never found it to be that much of an inconvenience. I absolutely HATE the way the Honda guys have to engage reverse with that stupid red button on the clutch lever.
Njrider1230
Jul 29, 2023 05:16 AM
Aug 21, 2015 01:23 PM
house1
Aug 9, 2015 10:49 PM
Schneider
Jul 24, 2015 05:05 PM
black_thunder
Jul 22, 2015 06:01 PM
