01 660 raptor problem HELP
Old Mar 20, 2007 | 10:35 PM
mstrquad's Avatar
Default 01 660 raptor problem HELP
the problem is the bike just lose power when riding. if i ride the clutch it keep running. is there a sensor or switch or broken wire????? where to start??? Ps it has gas. thanks for the help
Old Mar 20, 2007 | 10:51 PM
JLsparky7's Avatar
Sounds like you need to remove your e-brake.
Old Mar 21, 2007 | 11:20 AM
garyc660R's Avatar
Does the engine rev fine when sitting?
Old Mar 21, 2007 | 09:55 PM
RayneSavage's Avatar
Start with the simple....
Did you check your Air Filter, or recently oil it??? I had this problem once, and it was because I put too much oil on the filter. The higher the engine revved, the more air it required. Which in turn choked the carb, and the crappier it ran.
Let us know of any other details about the power loss....[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 23, 2007 | 09:38 PM
mstrquad's Avatar
it rev fine in neutral or if i ride the clutch. is it the parking brake switch. how do i test it? what are the 2 senser on the bottom of the motor by the shifter? thanks for a place to start.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
