banshee proplem
Old Apr 1, 2007 | 10:07 PM
beaty's Avatar
Default banshee proplem
when im messing around at home its fine but then i go to silver lake dunes and the throttle sticks and gets sensitive im thinking of getting new slides and new thumb throttle and cables my tors are removed eny advice please tell thanks
Old Apr 2, 2007 | 03:13 AM
JLsparky7's Avatar
Make sure the slides are clean. If your air filter is not tight then sand will get into your slides.
Old Apr 2, 2007 | 10:10 AM
zorro700's Avatar
I went to silver lake sand dunes and had my throttle stick too. It was an improperly prepared air filter had my slides full of sand which caused them to stick. One remedy I learned the second time out was panty hose over your filter helps stop some of the sand. I also started putting a film of grease around the filter where it seats againts the air box.
Old Apr 2, 2007 | 11:08 AM
beaty's Avatar
i have a k&n with the sticky stuff and then outerwear and i tighting it up as far as i can every time
Old Apr 2, 2007 | 12:22 PM
beaty's Avatar
i just pulled my air filter off and theres no sand and 1 slide works the other 1ns stuck wide open
Old Apr 3, 2007 | 08:01 PM
kfxandahemi's Avatar
Common problem with shees. Most times when pods are being used, they have been oiled with the wrong oil and it gets through the filter, and on the slides, gums them up and they stick. Im not saying you did that, but make sure you check that, and only use the correct oil for the type of filter.
Old Apr 4, 2007 | 01:42 AM
beaty's Avatar
iv got the k&n and i buy the k&n oil for it but it only happens at silver lake
Old Apr 4, 2007 | 02:37 AM
JLsparky7's Avatar
There has to be a reason why your slide is sticking. Take it apart and look.
Old Apr 5, 2007 | 12:15 PM
ClimbAnyHill's Avatar
& you're running the airbox? I had a prob with my K&N where there was a small gap behind the Pro Flow adapter plate & would suck sand in. I made a gasket out of an old bmx inner tube & sealed that plate & airbox really good. Make sure your cable isn't pinched anywhere. Take the carb top off, make sure the spring is pushing that slide back down & while you're at it give is a good spraydown with carb cleaner.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
