Trail Tech Vapor CPU
Old Apr 3, 2007 | 11:29 AM
bigwave's Avatar
From: South Central Illinois, NO where near Chicago, that's not my Illinois
Default Trail Tech Vapor CPU
Trail Tech Vapor CPU & Dash
Can anyone tell me how well these things work? I was considering putting one on my sons 05 Wolverine. How do the sensors hook up? Is there a physical connection somewhere between this thing and the quad or does it use some type of wheel sensors or ???. How durable are they, are they water proof?
Thanks
Old Apr 3, 2007 | 04:17 PM
2FAST4URASS's Avatar
I have the endurance trail tech it work's great but the vapor is much better as for functions anyways it come's with magnet bolt you replace one of you rotor bolts with it and run a cable to your wheel and drill out a hole the size of the end it normaly mounts on the lil disc guard.Heres a good link check it out it will tell you all u need to know. http://www.trailtech.net/media/instr...structions.pdf
Old Apr 3, 2007 | 11:52 PM
bigwave's Avatar
I'm interested I must say, it looks promising.
How water-prof is the thing, is it pretty much submersable? I'm looking at it for a 4x4 quad that will spend much of it's life in the local rivers, streams and mud pits.
Thanks
Old Apr 4, 2007 | 02:42 AM
Well ive never had mine 100% under watter but i was my atv with a pressure washer and hit the enduro with it to knock it clean not watter in condensation or nothin i would think it would be fine though for going under for short periods..But im not 100% on that...
oliveiracarlos
19
Nov 11, 2015 05:49 AM
Brandon400
Sep 5, 2015 08:44 PM
JakeXBL
Sep 5, 2015 01:08 PM
Canamaniac!
Sep 4, 2015 06:44 PM
blueandy88
Aug 31, 2015 12:42 PM
