Clutch Belt questions for woly 450
Old Apr 20, 2007 | 09:32 PM
Yamahaman06's Avatar
Default Clutch Belt questions for woly 450
hey guys I got my clutch apart and was looking at the belt and i like to replace it because it looks pretty worn and i surmerged the quad one and drained it and i think i burned up the belt tring to get back to my truck but anyway does the kodiak use the same belt?? dennis kirk has the listing for the 350 06-07 wolvy but not the 4x4. i refused to pay 141 bucks throught the dealer when i can get a goodyear belt for a 1/3 of the price. Thanks Anthony
Old Apr 20, 2007 | 10:05 PM
cluby's Avatar
No need for a new belt unless it has burt spot or is sitting too low in driven clutch. With the set up that yamaha uses you are not sapose to be able to burn the belt in the first place.
When you get water into the clutchs, it gets the grease in the drive clutch all over the place and is a pain to clean. Have even seen where mud and water got in clutchs and the belt was fine. Also can damage the rollers in the drive clutch.
Old Apr 20, 2007 | 10:56 PM
well thats good to know well the last time i rode i felt the belt slipping under a heavy load upon taking it apart tonight and looking at the weights in the basket theres no grease on them like the book is calling for could this be the reason it was slipping??? there was grease in it but it looks like it slung out might of gotten on the belt also have to clean everything up and repack it with belray axle greese. thanks for the info
Old Apr 21, 2007 | 09:09 AM
miassmaro98's Avatar
what book are you referring to
Old Apr 21, 2007 | 09:20 AM
cluby's Avatar
Ah I wouldn't put in just any old grease you may create problems doing so. I would just get the yamaha grease. The tubs that they have will do 3 clutchs. Take a airisal can top and fill it with grease level that's about how much to use.
Old Apr 21, 2007 | 01:33 PM
ctateusa1's Avatar
Definetly listen to Cluby
I have repacked my 450 clutch when the grease came out, 17.00 for a tub of grease and I used about 1/3 of it to repack my clutch when I did it.
Old Apr 21, 2007 | 01:35 PM
how will i know if i have to re grease it
Old Apr 21, 2007 | 02:05 PM
u1arunit's Avatar
There might be a maintence interval in the owners manual. I am going to check it.
I repacked mine when I installed the EPI clutch.
You should be able to inspect it but it will require disassembly.
Old Apr 21, 2007 | 02:12 PM
the book im refering to is the dennis kirk catalog, i wanted the yamaha grease but the dealer wouldnt order it for me because there a bunch of a**holes but the belray grease i got is just like the factory stuff and its water proof and wont loose consistency so it wont thin out so it should be alright i let everyone know in an hour when i give it back together. thanks Anthony
Old Apr 21, 2007 | 06:24 PM
cluby's Avatar
No No No, It's not the same and it will fly out and get all over inside, that's fine if you don't want to believe a tech that works on this stuff all day.
