How much will a 240cc Kit make a difference for a Blaster
it will have twice the torque and horse power an extended swingarm will be in your future it is twice as fast you need a 14 tooth front sprocket or it will rap out very fast did you get a bigger carb if so you will need a pro-design intake soon the stock air boot will crack and cause the motor to lean out who did the kit what company
were installing the kit at my friends machine shop this weekend and i Bought it from LaSleeve Co. right now i'm running a direct air cleaner to thr carb. I plan on using a 32mm Keihn Carb.By the way Blaster_14 what is your jetting?
