07 wolverine camber ??
Old Jun 6, 2007 | 07:44 PM
Jaybo777's Avatar
Default 07 wolverine camber ??
Just bought the wife an 07 wolverine special edition. Great looking quad, and looking forward to getting it out to beat it up. I had a question about the camber. I have a zuk 400, and did some suspension work, and took a lot of time to get the negative camber just right. Looking at the wolvy, it has positive camber on both front wheels (top of tire is further away from frame then bottom of tire). Is this normal, cause as far as I know there are no adjustments to change it. Any help is appreciated.
Jason
Old Jun 6, 2007 | 08:47 PM
jarmoore's Avatar
I noticed the same on mine. However, it's so slight that once weight is on it (a rider) it levels out.
Old Jun 6, 2007 | 10:10 PM
toddmh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jarmoore
I noticed the same on mine. However, it's so slight that once weight is on it (a rider) it levels out.</end quote></div>
same with my 03 really..I don't see anyway to adjust it either,just the toe in/out with the tie rods
Old Jun 7, 2007 | 10:07 AM
ctateusa1's Avatar
mine is the same way, but I dont believe that there is an adjustment, unless you find somone with aftermarket a-arms that are adjustable
Old Jun 9, 2007 | 04:00 PM
Jaybo777's Avatar
Thanks for the replies. I figured it was normal, just wanted to check with fellow wolvy owners.
Old Jun 9, 2007 | 08:35 PM
jarmoore's Avatar
Slightly off topic, but I tightened my shocks the other day. 4/5 on the front and 3/5 on the rear now (stock is 2/5, 2/5). I rode over 65 miles today and it's seriously like a different quad now. The ride is a bit more rough but it turns like it's on rails.
Also, don't bother getting the Yamaha key if you want to adjust them. I used a plain ole' adjustable wrench and it worked fine.
Old Jun 9, 2007 | 09:45 PM
07Wolvey450's Avatar
i did the same thing... it is completely different now, much less body role. i have them tightened all they way up so i can jump it a little, and it doesnt help at all, the shocks are junk. im gunna throw some rappy shocks on there soon
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
suzuki230
Jul 8, 2016 10:03 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
metal249
Jul 28, 2015 09:35 AM
Nelson
Jun 20, 2015 01:59 PM
