Raptor Pipe/Filter/Jetting
Old Jun 13, 2007 | 08:47 PM
YamahaRiderOnly's Avatar
Default Raptor Pipe/Filter/Jetting
I have a Stock 03 660 and I just got a HMF slip on and K&N filter .. I was wondering if it was good to cut the airbox lid a little bit and then put holes in the side of the airbox to get more air and what jetting I should run with this combo .. Thanks for the help ....
Old Jun 13, 2007 | 10:38 PM
buckaroo50's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: YamahaRiderOnly
I have a Stock 03 660 and I just got a HMF slip on and K&N filter .. I was wondering if it was good to cut the airbox lid a little bit and then put holes in the side of the airbox to get more air and what jetting I should run with this combo .. Thanks for the help ....</end quote></div>
If you cut your air box too much you will be running lean and somehow have to close it up again. Second thought comes to mind is water, how will you keep it out.
Jetting is determined by the color of your sparkplug. You make top end runs and at your fastest speed you kill the engine and slip it in neutral and stop and check the color of your sparkplug.
The link below has some good Q&A for you to read.
http://www.dfn.com/benkaren/jetfaq.html
Also check in the Arctic Cat forum for 'Air-jetting' there is a good solution for your air box if you are running rich. And it is a cheap fix, flexable and reversable.
Old Jun 14, 2007 | 03:58 PM
Anyone else have a Comment ?
Old Jun 14, 2007 | 05:47 PM
Fulltiltrider's Avatar
Just cut a square out of the lid. Take off as much plastic as possible without messing up how the lid holds on. I belive the rappy comes stock with 140-145 mains I would start with 155-160 and see where you are at, might still be a little lean but its a start
Old Jun 15, 2007 | 01:18 AM
StngGT350's Avatar
i have a 660r. i just leave my lid cover off when i want to race my buddies. and it does help a little.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
