Kodiak 400 rear end click
Old Jun 21, 2007 | 12:44 AM
joecat07's Avatar
Default Kodiak 400 rear end click
I recently purchaced a 400 kdiak 4x4 at a great price. After some minor carb work it runs great. My only concern is when i put it in gear somtimes it makes a click in the readend. The machine is all time fourwheel drive so i asumed its just the stress or pressure on the u joint and i was told it was normal in this paticular atv. Can anyone tell me if their machine does this and is it normal or should i replace the joint.. thanks
Old Jun 26, 2007 | 07:07 AM
olyguy12's Avatar
The older full time 4x4 units do not have a very straight angle on the front drive shaft and kills the U-joints. Take the dust cover off and you will most likly find the U-joint is worn out. The local Autozone should have the joint for $9. Its a 1982 Toyota Spectrum I think.
Old Jun 26, 2007 | 08:10 PM
joecat07's Avatar
thanks for the info.. my front end is ok i think.its the back u joint i think is the problem. the bike has very low hours on it but i bought it witht he full expectation of probable replacin some joints thanks again for the info
Old Jun 26, 2007 | 09:12 PM
beermanjoe's Avatar
I have a 1998 Kodiak all time 4-wheel drive with 800 miles on it and it doesn`t make any sounds from the rear end
Old Jun 26, 2007 | 10:43 PM
joecat07's Avatar
thanks for the post b man. s local atvmechanic said it could possibly be a u joint problem. im gonna wait and see how it does this weekend
Old Jun 27, 2007 | 12:52 AM
olyguy12's Avatar
The rear U-joint of the front shaft is just under the rear shaft. The rear shaft does not have a U-joint but a CV joint of some kind at the transfer case. Never seen or heard of the rear craping out other than the ring and pinion. It only takes a couple of hours to change the front U-joints so inspecting them only takes a couple of minutes, 10 and 12 MM sockets and a flash light. Does the whole bike rise up 3 or 4 inches before it moves? My 97 only has 6500 miles and bearly broke in. I have a friend that won a 96 in a raffle and put 32,000 miles on it before the speedo cable broke. He never had any problems with the transfer case portion of the rear driveshaft, but put in a couple ring and pinions, and front U-joints every 2-3000 miles. But it was replaced two years ago with a Rancher AT. As for beermanjoe, go put some miles on that thing for Gods sake. My last 2 day trip was 165 miles.
Old Jun 27, 2007 | 05:58 PM
joecat07's Avatar
ok. is the ring and pinion a big job money wse??
Old Jun 27, 2007 | 11:55 PM
olyguy12's Avatar
It seems like I heard the ring and pinion was in the $300 range for the parts. But play the odds. Check the front U-joints.
Old Jun 28, 2007 | 12:01 AM
joecat07's Avatar
thanks. i got such a good deal on this atv i dont mind spending alittle. it has low hours and a perfect engine. just sat out in the mans yard never abused. I apreciate the advise
Old Jul 4, 2007 | 12:10 PM
beermanjoe's Avatar
So what did you find out about your Kodiak?
