no fire
Old Jul 1, 2007 | 03:54 PM
yfzcdb450's Avatar
Default no fire
I recently stripped my YFZ to paint the frame and after I put it back together it wouldn't start. I checked the plug for fire and it wasnt firing. Swapped plugs...still no fire. I checked all my connections and the spark plugs with an ohm meter and everything is fine. When i checked to see if I had current coming through the spark plug wires my meter barely moved. The motor will turn over so I'm lost. Can anybody help??
Old Jul 1, 2007 | 04:47 PM
TacticZero's Avatar
Default no fire
is your kill switch on... not being a smart *** but sometimes you hit it with out even knowing.. and i know thats the last thing i check and i look like an ***
Old Jul 1, 2007 | 10:02 PM
yfzcdb450's Avatar
Default no fire
yea i checked my kill switch, if its off the motor wont turn over....
Old Jul 15, 2007 | 08:30 AM
Gunny63's Avatar
Default no fire
You need the basic three to run: spark, fuel and air. Check the coil, is everything secure and properly grounded? Good luck, let me know what you find.
ultangler
Nov 30, 2024 01:35 AM
mrtidy
Feb 3, 2016 05:00 PM
IMLN
Sep 28, 2015 03:32 PM
Elkaholic
Sep 6, 2015 02:44 PM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
