1999 Big Bear carb
Old Jul 8, 2007 | 08:33 PM
jguidry's Avatar
Default 1999 Big Bear carb
Can someone please help. I have cleaned and reset this carp to specs but it is still spitting back through the carb. Could this be a valve problem? Also the owner has gutted the muffler, does this have any effect on this machine.
Old Jul 8, 2007 | 09:23 PM
Lasvegascop's Avatar
Could be the valves, get a manual and adjust them, Ite pretty easy on the Big Bear.
check your spark plug. See if it is a nice tan color. Or replace it.
What do mean gutted the muffler?
If they "gutted" the muffler then u may be running lean.
What throttle position does it sputter at? 0-1/4, 1/4 to 3/4, or 3/4 to full?
clean and re oil your air filter.
I have a 99 Big Bear also.
I had to completely disassemble the carb, including removing the jets and blowing out each jets chamber with carb cleaner and compressed air and adjusted the valves...
It runs like a champ now.
Old Jul 9, 2007 | 08:27 PM
jguidry's Avatar
Thanks LAcop. I think I have eleminated the carb as the problem I took one off of another bike that was running good and it did not make a difference. I may have and exhaust valve not seating properly or sticking. It is firing back though the carb from 0 to half throtle but if I am gentle with it sometimes it will throtle up but start to cut up again when I come down and try to go back up with it.
Ean
Dec 19, 2022 08:48 AM
clsharky
Jul 13, 2015 02:07 PM
micheleLeigh
Jul 12, 2015 02:50 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
