Blaster Bolt Question?????
I am in the process of replacing my crankshaft seals and I did the flywheel side seal the other night and there are 2 long phillips head screws that hold the stator in once the flywheel is removed. I stripped on of those bad and thankfully was able to get it out. This doesn't look like a regular screw but I found one at the local hardware store that would do the trick. The one I found is a hex head and its not stainless but is there any reason for concern with me using this or should I order from the Stealership? I just didn't know with they flywheel being magnitized and I have so much crap to do on this thing would hate for something stupid like to this to screw it up. I also have one on the Crankcase that was stripped and found a hex head 8mm bolt that I think will work but the head is a little different then the stock one so hopeing that will work as well? Any thoughts and oppinions would be much appreciated. Thanks.
Chad
Chad
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
skeets44
Jul 17, 2015 01:04 PM
