best exhaust for raptor
<div class="FTQUOTE"><begin quote>Originally posted by: raptor35091
Wats the best exhaust for my raptor 350 best power gains. And how much to new sprokets help out . Hot cams How do they help give me advice</end quote></div>
In my opinion, HMF slip-on is the most bang for your buck on a 350. You won't be disappointed. I would keep the stock rear sprocket and once you replace the exhaust, filter, and re-jet your carb, then replace the front sprocket with a 14 tooth. That will take a little from your bottom end, but give you a little more top end speed. You could replace the front sprocket with a 12 tooth, but that will kill your topend speed, but give you a lot of bottom end. So, it all depends on what you want. Hotcams are little boy cams. If you are going to install a cam, you may as well get a good one, like a Webcam with .430" lift or similar. You need all the help you can get on a 350, so I wouldn't **** around with the Hotcam. A cam helps ALOT by allowing your engine to rev a LOT faster than factory. You can take a nap while waiting for a stock 350 to rev up. Oh, and how about working on that grammar? It's hard to understand your questions!
Sep 10, 2015 01:56 AM
