04 Raptor 660R
Old Aug 22, 2007 | 09:25 PM
darkone1990's Avatar
Default 04 Raptor 660R
I have an 04 Raptor 660R and the reverse light is flashing. What does this mean?
I am looking for a big bore kit. Need manufactors names.
Strocker kit; need manufactors names.
Old Aug 22, 2007 | 11:58 PM
Liarsenic.'s Avatar
Ice Cube is a good bolt on bore kit. Not the right choice if your on a budget. Athena is the same thing for about half the price.
Old Aug 29, 2007 | 12:32 AM
MasterRaptor's Avatar
Reverse light flashes when your idle is over 2000 RPMs. Try to Adjust it down.
To go to a 686, all you have to do is buy a 102mm piston and bore the cylinder 2mm over. CP pistons work the best in a 660. Weisco makes a great stroker crank and rod. A rod change is a must. The stock one will break for sure if you do a big bore. Send the head to Craycraft Racing for porting. To really wake it up, add FCR carbs. Good luck!
Old Aug 29, 2007 | 03:54 AM
The1Hater's Avatar
as for the big bore/stroker kit i would go to barkersbars.com and get his +4 stroker crank, rod, and a 12:1 piston. a stroker set up is a little more expensive, but is better than a big bore. team that up with a new cam and you have a great set up. if your in the market for a cam i am selling a 696 gring web cam for $90.
Old Sep 8, 2007 | 01:09 AM
To: MasterRaptor
Thanks, that was the problem.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
