06 wolverine hmf pipe jetting ?'s
Old Sep 4, 2007 | 10:06 PM
mxer021's Avatar
Default 06 wolverine hmf pipe jetting ?'s
i just got a 06 wolverine with an hmf pipe and epi clutch kit. it seems to be running a little lean, i was just wanting to know what is the size of jets that come with the kit when you buy the kit. thanks
Old Sep 4, 2007 | 10:12 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
it should say on the jet itself
Old Sep 4, 2007 | 10:56 PM
MIwolvy's Avatar
What kit? I believe the pipe comes with a 140 jet. My wolverine is at the shop right now getting jetted, I added a K&N filter and a hmf pipe, and had them jet (dynojet kit) it last week. When I got it home, I couldnt get it over 46mph...it just sputtered, so Im guessing it was leaning out at the top of the RPM band....so I brought it right back, they are still trying to get it right.
When they get it running 100%, I will let you know what jets they used.
Old Sep 6, 2007 | 10:00 AM
derrelw's Avatar
Your altitude, the air temp and humidity all factor into jetting but if you go to dynojet's website and look up your bike with your specifics it will give you a pretty good idea where to start. BTW my main jet is a 124. (I live at 5600 ft. in the New Mexico desert)
Old Sep 6, 2007 | 10:16 AM
ctateusa1's Avatar
With the gytr pipe, k&n air filter and clutch kit here in arkansas I have a main jet of 132 and it runs perfectly.
Old Sep 6, 2007 | 07:26 PM
joaquin's Avatar
Mine came stock with a #131,5. Them I put an HMF pipe and FPS clutch kit and I putted a #140 (the pipe came with a 135, 140 and a 142,5). It runs great, no problem, and about the same top speed I got when it was stock (53MPH). I run it at about 1000 ft of elevation.
Old Sep 10, 2007 | 09:32 PM
mxer021's Avatar
ok cool i will look on dynojets web site and see what i can find
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Brandon400
Sep 5, 2015 08:44 PM
