87 moto 4 350
will a carb from another quad fit this and if so what quad
87 moto 4 350
i swear man every time i post a question on here i get no response. so i assume nobody on this website knows the answer to my question or i guess because i dont have a new kodiak or raptor ect i am not good enough for your info
87 moto 4 350
some people just don't have the answer man, i've never even SEEN a moto 4 350.. let alone know what carb would fit on it... check ebay.. there might be a stock carb on there
87 moto 4 350
Yeah it's not like the Moto 4 350 is known for swapping out parts. You may just have to do trial and error tests yourself. It would probably be in your best interest to stay with a stock Moto 4 carb if you can. You can rig up a lot of carbs, Ive even seen a Warrior with a 400EX carb before! But doing swaps like that could make it hard to adjust correctly. But if you insist on another carb, I would start looking at the other Yamaha 350 engine's carbs, like the Wolverine, Warrior, etc. Why do you need another carb? If you have one they can usually be rebuilt.
87 moto 4 350
speedy thanks for your reply
87 moto 4 350
Hey - what about me? You didn't like my reply?
87 moto 4 350
YOU TO RAPTOR THANKS FOR THE INFO
87 moto 4 350
I JUST GOT THIS THING AND I T DOES NOT HAVE A CARB ON IT AND I WAS WANTING TO KEEP MY OPTIONS OPEN IF ANOTHER CARB WOULD FIT
87 moto 4 350
<div class="FTQUOTE"><begin quote>Originally posted by: mikeyp2
YOU TO RAPTOR THANKS FOR THE INFO</end quote></div> I was just messing with you. I'm not a crybaby like that. I'm not a carb guru, but common sense tells me if you get a carb close to the original size, you can make it work. Like if the stock was a 28mm, try to find a 28-32mm. You probably wouldn't want to go to as high as a 36mm. I don't know exactly what the stock size is, but I'm just throwing some numbers out there. |
