06 raptor 350 motor noise
Subscribe
Sep 11, 2007 | 02:34 PM
ok
i got noisy valve train.
when you go to check the valves on top dead center they are good, when you turn the motor a little past the rocker arms are really loose.
it runs good .no miss has good compression.
what happen was riding hard and out of nowhere started making noise.
any help thanks
Reply 0
Sep 11, 2007 | 05:11 PM
loose valves
Reply 0
Sep 11, 2007 | 05:46 PM
but why are they tight on top dead center where you adjust them
and then when turn the motor say 20 degrees past they get very loose .
Reply 0
Sep 11, 2007 | 06:01 PM
Are you sure you are at top dead center? You could be 180 degrees off and the piston is really at the bottom. When both valves are closed, both rocker arms will be loose, AND the "T" should be visible thru the peep hole.
Reply 0
Sep 11, 2007 | 06:08 PM
yes
and all maks lined up
valves adjusted to specs
it is when you past top dead center they become loose , like 20 to 30 thousands loose and the valve opens.
when it is running it sounds just like a loose tappet.
could it be something else causing the same noise
Reply 0
Sep 12, 2007 | 01:10 AM
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
Are you sure you are at top dead center? You could be 180 degrees off and the piston is really at the bottom. When both valves are closed, both rocker arms will be loose, AND the "T" should be visible thru the peep hole.</end quote></div>
No not 180 off, 360 degrees a full turn of the flywheel.
You could adjusting your valves on over lap and not compression. When you have all the marks lined up the piston both times will be at TDC in the bore.
The simple way to do it or to double check is either pull the cam cover off and look at the mark. Or as you rotate the flywheel counter clockwise you will see the exhaust valve starting to open if you were on the right stroke.. compression. The next stroke would be exhaust. If you were on the wrong stroke, which it does sound like you would see intake start to open.
You should have about .003 intake and .004" exhaust.
The warrior does have a tappet noise when warmed up more so then other engines.
Reply 0
Sep 12, 2007 | 09:29 AM
ok understand.
everything is line up ,on the right stroke.
the valves adjusted
it is when you turn the motor a little bit the valves get very loose.
(mainly the exhaust valve)
my question is why?
something has to be wore somewhere in order for this to happen.
thanks
Reply 0
Sep 12, 2007 | 06:56 PM
I agree.. the cam has to be worn. If you turn the engine over on over lap the engine will be coming off of exhaust and going to intake. You can actually see the valves moving. So if you adjusted them on over lap and start turning the engine over you will see the exhaust get very loose.
When you set the valves the first time where they loose or tight?
Reply 0
Sep 13, 2007 | 09:08 AM
they were right on in spec
Reply 0
Sep 13, 2007 | 04:59 PM
FOUND IT
broke camshaft
Reply 0
