06 wolverine suspension question
Old Oct 28, 2007 | 09:03 PM
redjeepguy's Avatar
Default 06 wolverine suspension question
i read a post a while back and someone gave some numbers of the psi and suspension settings they were using to get the maximum performance out of their suspension. when i hit corners pretty fast, the nose dives, and im trying to correct that as much as possible with the factory suspension. so in short, what are you guys running as far as psi in the front and rear tires, and what is your suspension setup?
as far as my riding style, i do mostly trail riding and small amount of track riding (small tracks). any help would be appreciated.
Old Oct 29, 2007 | 12:52 AM
yotatrailrunner's Avatar
I put the shocks on the 2 in the front and 3 in the back and run the front tire pressures at 8 and the rears around 5. It really helps with the cornering
John Reed
Sep 9, 2015 03:46 AM
chewy78
Sep 8, 2015 10:37 AM
bmark0610
Sep 7, 2015 09:42 PM
MooseHenden
Sep 6, 2015 04:24 PM
Logan Collins
Sep 5, 2015 08:03 PM
