Big Gun JETTING Dialed In
Old Jan 12, 2001 | 11:01 AM
RAPTOR1's Avatar
Bartolo,
I am in ohio and have the biggun head pipe with the white bros silencer(disc type). I put 160/165 with 27.5 pilots last night. It has instant throttle responce. I also have a white bros air fliter and two one inch uni vents in the air lid which really made it lean prior to the jetting. So far this really seems to work good tonight I will get more ride time on it and see how it goes.
mike 01 raptor
Old Jan 12, 2001 | 01:07 PM
bartolo's Avatar
Raptor1,
Where did you get your uni-vents?
Thanks,
Bart
Old Jan 12, 2001 | 01:36 PM
RAPTOR1's Avatar
Bart,
I got them at my local dealer. I believe it was $5 for about 6 of them in the package. If tonight I find to be still a little rich I am going to put two more vents in the lid. I look on the box and see if the is a part # if so I e-mail you later.
mike
Old Jan 12, 2001 | 05:45 PM
bartolo's Avatar
RAPTOR1,
What would be the disadvantage of just cutting a huge hole in the top of the air box lid? The filter would still be kept in place by the air box lid's perimeter.
Old Jan 12, 2001 | 06:22 PM
  #15
No2StrokeBs's Avatar
Did you change your jets yourself? How long did it take you? What are you doing about the crackcase vent that runs to the stock baffle?
Old Jan 12, 2001 | 06:25 PM
  #16
Are you doing your own jetting work? How long is it talking you to change 2 carbs worth of jets? I have the 150, 155 setup right now,and it lays over onthe big end, I have 2 sets of jets, a 152.5, 157.2 and a 172.5, 177.5. Which ones do you think i should go with?
Old Jan 12, 2001 | 07:07 PM
  #17
bartolo's Avatar
No2StrokeBs,
Actually, I took mine to the dealer to have it jetted. They charged 1 hour per carb. I'm not sure I know what crankcase vent you are talking about. I installed the exhaust and there was no hose to the baffle. Do you have a CA model?
I'd hate to tell you what jets to use and then it be incorrect. I can tell you that the 160/165 with 27.5s and with stock air setup is a little rich. However, with the air box modified and/or an aftermarket filter, it seems to be the perfect combination! I just did a little wheely exhibition for the neighborhood kids and that thing now pulls HAAAARD in 2nd gear!!!
Old Jan 15, 2001 | 10:13 AM
  #18
RAPTOR1's Avatar
Hey guys,
SOrry for taking so long to get back to ya.
Bart, if you cut away a lot of the lid water and dirt will have direct access to your filter. The vents allow plenty of air and keep almost all water and mud out. The vent also have cleanable foam in them to filter out the dirt!
Old Jan 15, 2001 | 10:24 AM
  #19
RAPTOR1's Avatar
No2strokes,
I did all the work my self. If you take the front plastic and the fuel tank off it is really simple to do. Once you can get to the carbs it t
akes about 3 minutes to jet each carb-no lie. When you get the plastic and tank off the bike loosen the carbs from the boots pullthem back and turn them upside down and re-jet. I used 160/165 mains and 27.5 pilots. Rode all day sunday about 40 degrees out here, checked the plug and it is a dark brown>(perfect). The bike really did pick up some power too. It pulled away on the street from my fiends all stock raptor about 2 bikes we rolled on 3rd gear thru 4th and ran out of room.
hope this helps
mike o1 raptor
Old Jan 15, 2001 | 01:57 PM
  #20
Are you running any type of free flowing filter setup? I am thinkin about installing 172.7 and 177.5 with the Pro Design filter and the complete BG exhaust. Do you think that this will be too rich?
