2007 RAPTOR 700
PLEASE CAN SOMEONE ADVISEWHAT I CAN DO TO MY RAPTOR 700 FOR SOME MORE PERFORMANCE .
I HAVE ORDERED A HMF PIPE , INTAKE KIT & K&N AIR FILTER , DO INEED TO DO ANYTHING TO THE AIR BOX ??
I HAVE BEEN ADVISED AGAINST USING A "HOT CAM"
THANKS
CLYDE
THANKS
CLYDE
make sure you get a fuel controler. i whould recomend the pc3. if you buy that one you will never need to upgrade again. other thing that you can do is bore out your throttle body and you can also get a new ingtion system for them also. both of this upgrades dont hurt the reliabilty mutch at all also. good light wheels and tires will make your quad alot faster also.
the HMF OPTIMIZER is a fuel controler. and ingtion is seperate. if you plan on upgrade your power much ferther you will have to get a power commander 3 fuel controler.the hmf one is alright for now though. and if you plan to bore out your throttle body there are a couple of guys on raptorforum.com that do good jobs.
<div class="FTQUOTE"><begin quote>Originally posted by: clydeuys
I HAVE ALSO GOT THE HMF OPTIMIZER FOR THE BIKE , IS THAT OK FOR THE FUEL AND IGNITION</end quote></div>
Yes that is just a repackaged Dobeck and it will work fine for fuel control. Ignition control will be a seperate thing if you ant to add that.
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
